Interior Light Problem on 1999 Solara - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-02-2008, 01:11 PM   #1 (permalink)
View mfox20's Photo Gallery
I have a interior light and clock issue that began a couple of days ago. I will describe the issue below and what I have checked so far. Any input would be appreciated.
1. Open any door, dome light does not come on and the clock goes out then resets to 1:00.
2. Turn on any inside light switch such as the map light or vanity mirror light, no lights will come on and clock goes out then resets to 1:00.
3. Open trunk, same symtoms as in 1 and 2.
It appears that 12 volts becomes not available to these items when any light switch changes position (door switch, map light switch, etc...). I checked voltage in the passenger side vanity mirror and showed about 9 volts only.
Battery voltage is about 12.6 and alternator is delivering about 14 volts. I am not seeing any battery drain down overnight.
Bulbs were checked for continuity and appear to be good.
I am not sure where else to look, maybe I missed a bad bulb, bad switch, bad ground. Everything appears to be related to the courtesy type lights.
Any thoughts?
Again, I appreciate any insight you might provide. We purchased the car new in 99 and it has about 131k and has had very few issues.
Michael
mfox20 is offline   Reply With Quote
Old 03-28-2011, 02:43 PM   #2 (permalink)
View pjfaith's Photo Gallery
Was was the fix on this problem? I don't see where you can find the answer to peoples car problems....
pjfaith is offline   Reply With Quote
Old 03-30-2011, 03:28 PM   #3 (permalink)
View Lauer340's Photo Gallery
It sounds like to me you're shorting somewhere. I would start with checking your fuse panel located under your steering wheel on the inside of the change holder. Make sure you have the right fuses. If that checks out, make sure your car is grounded properly from the battery. That could cause a malfunction but I doubt. Cause it sounds like, every time you pull energy for these lights it's drawing energy then suddenly stopping all. So next I would check to make sure your wires and plugs are all tight and not burned out behind the console. Idk other then that...
Lauer340 is offline   Reply With Quote
Manual driver seat problem satamas 9th Generation (2003-2008) 0 11-05-2007 08:30 AM
08 Solara Navigation problem tivofred Solara 4 09-06-2007 06:15 AM
Price check on 1999 Solara SE, V6 5 speed 51K miles etc 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-30-2007 06:43 PM
For Sale 1999 Toyota Solara hyego Vehicles 4 08-17-2007 02:51 PM
99 Solara Speedometer problem kamry2002 Solara 3 08-09-2004 12:53 PM
