2000 solara SLE NEED HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-09-2008, 06:06 PM   #1 (permalink)
View beem4567's Photo Gallery
Hello, Ive replaced the altenator because each time tried jumping my car it seemed as if the battery was not recharging. Then after that the car still wouldnt run i then replaced the battery. The car started and seemed to run normal except now i have no power options inside the car except the interior lights. the blinkers dont work the stereo the gauges, power seats etc. the second time i started it the idle seemed way too low it was way quiter than normal and still no power to guages or anything else. I NEED HELP, what could it be? oh and my headlights do work.
beem4567 is offline   Reply With Quote
Old 01-09-2008, 06:47 PM   #2 (permalink)
Mr E's Avatar
View Mr E's Photo Gallery
check ur fuses.
All of them.
Penelope ~ AE86 4AGE;Maxine ~ A32 VQ30DE;Madonna ~ MX73 5MGE
Mr E is offline   Reply With Quote
Old 01-09-2008, 07:06 PM   #3 (permalink)
i did check all of them they are fine.
Old 01-09-2008, 07:28 PM   #4 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
is it a brand new alternator or a used one? I had a similar scenario with my gen 3 camry and it ended up being a short in the reverse light harness.
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 01-09-2008, 08:05 PM   #5 (permalink)
refurbished i believe. So your short cause almost a complete power group disfuncition. I acutally cant even get it into gear as well i had to take off the little clip on the shifter base and push in the button to put it into to gear to drive.
Old 01-09-2008, 08:10 PM   #6 (permalink)
93 240sx SR Hatch
DAMON's Avatar
the short was causing the gauges to not work, turn signals, windows, heat and ac, and the shifting was messed up... all from one fuse blowing in the reverse harness every time I put the car in reverse. You may want to have the alternator checked, I had one for 2 months that went bad on me and had similar issues... couldnt believe it.
Old 01-09-2008, 08:23 PM   #7 (permalink)
View toyomoho's Photo Gallery
Have you checked all of the fuses and fusible links? There are most likely at least 4 fuse boxes on the car. Have you checked the battery cables and the cable from the alternator to battery?
Use a voltmeter to check battery voltage with engine running at around 1500RPM, should be 14.1-15V if alternator is working.
Check the wires in the trunk where the harness jumps from the chassis to the trunk lid,this is a common location for wire damage.
Old 01-09-2008, 08:53 PM   #8 (permalink)
hey i checked again in better light i found the problem, 100 AMP fuse blown for the altenator circuit. Thanks for your help
Camry Solara Melds Style And Comfort In Coupe And Convertible Models humanoid Toyota News 0 10-06-2007 03:06 PM
2000 Solara SLE V6 Rattles at 2000 RPM ETCdude Solara 2 07-07-2007 05:10 PM
2000 Toyota Solara SLE chago Introduce Yourself Here 3 06-16-2005 11:23 AM
wobbling sounds from new tires/wheels on 2000 Solara SLE Amazingly Smooth Solara 11 09-11-2004 01:06 AM
2000 Solara SLE brakes Amazingly Smooth Solara 2 01-06-2003 11:40 PM
