2002 4 cyl rattle, then squelch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-15-2008, 05:45 PM   #1 (permalink)
View coastal_eddy's Photo Gallery
I am a new member, appreciate any helpful replies. I checked 34 pages of forums and read a few related issues.
My 2002 Solara 4 cyl. has a noisey rattle at idle then sqelches at acceleration. Runs fine but, sheesh the noise. Been using penetrating oil to reduce the sqelch. If tensioner pulley, can just I replace the pulley and bearings only (its attached with a bolt) or do I have to get the whole tensioner? Could it be belt slippage? Or possibly something else? Water pump is not leaking. Thanks!
coastal_eddy is offline   Reply With Quote
Old 01-17-2008, 11:12 PM   #2 (permalink)
My own reply
Found a TSB matching my issue, thanks. Alldata.com or toyota.com
Coolant drain plugs on block? 2002 4 cyl makinson 5th & 6th Generation (2002-2006 & 2007-2011) 14 02-15-2008 09:10 PM
Tsb Bulletin El Tano 5th & 6th Generation (2002-2006 & 2007-2011) 20 11-29-2006 12:47 PM
2002 Highlander Glovebox / Interior Rattle JennyS90402 General Discussion 1 08-18-2005 08:10 PM
2002 Camry 4 cyl - Suspension Sucks? 2002CamryNJ4cyl 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-23-2005 12:25 PM
unf\date on rattle in 2002 tacoma Dash bamatoyota 1st Generation (1995.5–2004) 4 02-20-2004 09:46 AM
