Lowering Springs Damaging Shocks? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-20-2008, 06:46 PM   #1 (permalink)
View liquid2's Photo Gallery
Hi! I'm a new member here, just got a 2004 solara se!
I have a question, when you put in the TRD lowering springs, over time would that damage your stock shocks? Would it be wise to buy a new set of shocks or something to pair with the TRD lowering springs?
The reason is..I don't want any surprises down the road ..
If anyone has had it installed at a dealer and could tell me how much was charged, that'd be great!
Also, about rear sway bars how much of a difference do they make in the handling of the car? I came from an accord and lexus and the ride of the solara is comparable to the lexus, but the problem is i'd prefer a stiffer ride.
Thanks!
liquid2 is offline   Reply With Quote
Old 01-20-2008, 07:17 PM   #2 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
It is not wise to run lowering springs on stock struts because then the strut is compressed more of the time- thus causing it to wear out faster. If you want to go with lowering springs, go with some high quality struts as well like KYB or Tokico. Those will be designed to hold up with lowering springs and you wont have issues down the road.
The rear swaybar makes a big difference in body roll on the gen 1 solara... I would imagine it to make a difference on the gen 2 as well. The car will corner flatter, understeer less, and feel more responsive.
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 01-22-2008, 06:29 PM   #3 (permalink)
View Sebas007's Photo Gallery
The SE model has stiffer strut...it is your best bet ! I've myself a 2006 Toyota Solara V6 sport and I have no problem with my suspension (2 years running on bad Quebec roads)
Since you're from CA I would buy some Tein SS C/O it would be the thinkg to do....at around 1200$ you're set.
Sebas007 is offline   Reply With Quote
Purple Gen 3 lowering springs? Durrby 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-21-2005 10:15 PM
Question for the people with lowering springs.. strmagiceet Camry & Solara Lounge 18 04-14-2005 06:25 PM
Lowering springs or sports springs....cut down threadwear on tires? coolchu001 Camry & Solara Lounge 15 03-16-2005 09:12 PM
Camry 2003 lowering springs choices...please help! OrangeJuice 5th & 6th Generation (2002-2006 & 2007-2011) 4 02-02-2005 10:08 PM
Please read! Need advice! Lowering springs slipknot490 1st Generation (2003-2008) 1 10-07-2004 09:41 PM
