Repeated Battery Failures
I have a 2002 Solara with 81,000 miles. In the 5 years since I've had my Solara, the battery has failed 5 times (today for the 6th time). Each time, the car won't start at all, jumps fail, and it has to be towed. I've had it taken to the dealer since it has a 100,000 mile warranty.
Each time, the dealer runs tests (load test, drain test, etc.) and determines there is nothing draining the batter and that the battery itself is "defective." I've also had them check the starter, alternator, fuses, etc. and everything else checks out. Each time, the dealer then replaces the battery and the problem is "fixed." Anywhere from 6-12 months later, we start over. There are no after-market parts or electronics on the car that could be draining the battery.
Except for this problem, the car has been trouble free and all regular maintenance has been performed on schedule. It seems statistically improbable that I've had 5 defective batteries in 5 years.
Any thoughts or ideas about what could be causing this and how I can solve the problem? Thanks!
