Engine Fans dont work - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-02-2008, 11:32 PM   #1 (permalink)
View ajbrodie's Photo Gallery
I have as 2000 solara sle v6 and my engine fans dont work. what can be the problem
ajbrodie is offline   Reply With Quote
Old 04-03-2008, 07:12 AM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
1. The coolant isn't warm enough to trip the switch
2. Bad water temp or pressure switch
3. Blown fuse
If the engine is overheating even when moving down the road it may not be an issue with the fan(s) at all, but a bad thermostat.
Assuming #1 isn't the case I'd check #3 first and if that's good then you'll have to test the switch(es).
Cheers
Gadgetjq is offline   Reply With Quote
