Low tire pressure light on and off - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-20-2008, 05:43 PM   #1 (permalink)
View kwanpen's Photo Gallery
i have a 04 solara. I just replaced all 4 tires of my car. However the low tire pressur elight turns on upon changing, i went in and found out its a valve stem. So got that fixed, and now the low tire pressure lights will turn on after 5-10 min of driving and then turn itself off after another 5 min and never turn on again. I checked the tire pressure and everything is up to specs. ~30 pisg on a 29 psig tires (dont know will 1 psig over specs will cause problem) Do anyone know whats wrong?
kwanpen is offline   Reply With Quote
Old 04-20-2008, 06:54 PM   #2 (permalink)
View slyfox75's Photo Gallery
Have you checked pressure of spare tire?? Not sure if Solaras have TPM on spare but some Toyotas do.
slyfox75 is offline   Reply With Quote
Old 04-20-2008, 08:14 PM   #3 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
If you read your users manual about changing tires and the tire pressure system. You need to recalibrate it every time you change your tires. Once you have verified they are at the correct pressure, turn on your car and hold down the tire pressure button under the dash untill the TPM light flashes a few times and then turns off. At that point it will relearn it's known good values.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 04-20-2008, 08:35 PM   #4 (permalink)
i did that..those are the conditions that i got after i have reset my pressure light
Old 04-20-2008, 08:38 PM   #5 (permalink)
I smell McNuggets
[SMAN]'s Avatar
well the 04 solara measures wheel rotation on all 4 wheels, and if they aren't lined up with their known good values, it throws the light. So the spair is not needed. Perhaps you improperly reset the system, you can try resetting it again (you need to hold it down for like 30 seconds when the car is not moving) if that doesn't fix it, then perhaps you have a faulty sensor (but that's a streatch)
Old 04-21-2008, 10:03 AM   #6 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
i have a 04 solara. I just replaced all 4 tires of my car. Now the low tire pressure lights will turn on after 5-10 min of driving and then turn itself off after another 5 min and never turn on again.
Are you sure you're actually resetting the warning system? If you just push the button and don't hold it in you'll turn the light off, that's all.
Push the button, hold several seconds until the light blinks 'then' you've reset the system. The system will 'assume' your tire pressures at that moment are correct even if one side is far different from the other so be sure your cold pressures are correct and are the same (on the same axle) before resetting.
Cheers,
Gadget
Gadgetjq is offline   Reply With Quote
