problem with power windows - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-21-2008, 08:06 PM   #1 (permalink)
mloewen's Avatar
View mloewen's Photo Gallery
Hi I recently got a 2000 Solara . Today my power windows both stopped working. Where is the fuse box for windows?
mloewen is offline   Reply With Quote
Old 04-21-2008, 08:45 PM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
The answer should be in your owners manual but if the Gen1 is the same as Gen2 is in the under hood fuse box.
Make sure you don't have the window switch lockout turned on if you have one.
Cheers
Gadgetjq is offline   Reply With Quote
Old 04-21-2008, 11:31 PM   #3 (permalink)
mloewen's Avatar
I finally found it
Thanks I finally found it in manual. It is under the hood. I have not had a chance to check it yet.
Now the passenger window is working. Anybody know if this indicates anything?
Old 04-21-2008, 11:55 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
I think your window motors are on it's way out.
Usually when they heat up they slowly work and finally stops working.
Let it cool down some and they'll start working again and eventually quit.
Also maybe partially broken wires in the harness from the door going to the body is a possibility.
Nad1370 is offline   Reply With Quote
