Tire Pressure Monitoring System - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 05-01-2008, 02:39 PM   #1 (permalink)
View cehe4ka's Photo Gallery
Just got an 04 Solara with the Tire Pressure light ON.
Are there supposed to be valve-stem sensors in the tires? Every OEM system that I saw had those, but this car has rubber valve-stems.
Thank you.
cehe4ka is offline   Reply With Quote
Old 05-01-2008, 04:30 PM   #2 (permalink)
View toyomoho's Photo Gallery
Toyota does have a system that is inside the tire mounted on the rim. Have you checked the spark tire for air pressure?
Old 05-01-2008, 04:32 PM   #3 (permalink)
No did not check that one yet.
Is there any way to find out specific system used in my Solara?
Old 05-01-2008, 06:11 PM   #4 (permalink)
The owners manual should say something about the system. Tire monitoring appears standard on this year thus would assume it has the rim mounted system.
Recall the system compares tire pressure against a standard set in the computer (including full size spare tire if equipped). The standard can be reset if the tires require a higher or lower pressure.
Old 05-01-2008, 10:32 PM   #5 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Originally Posted by cehe4ka View Post
Just got an 04 Solara with the Tire Pressure light ON. Are there supposed to be valve-stem sensors in the tires? Every OEM system that I saw had those, but this car has rubber valve-stems.
Solara doesn't have the valve mounted sensors until the '07 model year.
The '04-'06 Solara uses the anti lock brake sensors to determine whether one wheel (on the same axle) is turning at a lower rate than the wheel on the other side. If so the light will come on notifying you that at least one tire is low on air. It's up to you to figure out which one.
The later (active) system actually tells you which tire has low pressure including the spare. Spiffy except eventually the sensors have to be replaced, batteries can fail so there's some maintenance involved.
If your pressure light is on (this info is in your owners manual)
1. Check each corner to be certain you have the pressure you want in each tire.
2. Turn the key on (no need to start the engine) and press the calibration button (lower left side of dashboard) holding the button several seconds until the light blinks.
3. Release the button. Note, if you just stab the button you'll turn the light off but it'll come on again after you've driven a couple of miles.
Anytime you rotate your tires there's some chance the light will come on depending on your method of rotation and whether you keep the same pressure front/rear or not. Just don't be surprised when the light comes on anytime you rotate and especially when you get new tires mounted.
Cheers
Gadgetjq is offline   Reply With Quote
