2002 solara to do list - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 05-09-2008, 04:27 PM   #1 (permalink)
mecampo's Avatar
View mecampo's Photo Gallery
Cool 2002 solara to do list
hi peeps,
I just got a 2002 solara I4 with 87K miles already.
I wanted to replace stuff like sparkplugs and wire set, air filter, battery but I really don't know if there should be priorities on this, what goes first, or if you have suggestions what to check and replace too.
All suggestions will be very much appreciated.
Thanks you all.
mecampo is offline   Reply With Quote
Old 05-12-2008, 08:59 AM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Check the owners manual. It may have a maintenance schedule for you to follow.
If you know the history of the car (previous owner (po) gave you all the paperwork) you're in good shape, you can work from that. If not then I'd start with a complete change of all fluids. Brake, coolant, oil, transmission fluid/lubricant (depending on the trans).
A spark plug change wouldn't be a bad idea but before buying new plugs pull a couple and see what kind of shape they're in. Plugs last a very long time now so if they aren't worn just check the gap and re-install. When changing plugs be sure you use anti-seize on the threads to prevent the plug from 'welding' itself to the cylinder head. Plug wires can be checked for resistance. If they're within spec (check a factory service manual) then you're good to go, no replacement needed.
If there aren't any starting issues the battery is probably fine. Check to see if the po wrote the purchase date on the outside someplace if you can't find a receipt. If it's the OEM battery then yes, it'd be a really good idea to replace it.
Air filter, again, check the maintenance done but if there's no record take a look at the filter. If it's dirty change it if not put it back in.
Oh! You might want to take a look at brake pads (front) shoes (rear) just to be sure there's lots of friction material left. If the po did a lot of around town driving then he/she would have used the brakes more than a highway driver.
Clean the throttle body throat. Hardly anyone does it as part of normal maintenance. A thin ring of carbon builds up in the throat where the butterfly contacts the edges and has a big effect on engine operation, especially idle. All you need is a can of throttle body cleaner and an old toothbrush.
Cheers
Gadgetjq is offline   Reply With Quote
Old 05-12-2008, 06:08 PM   #3 (permalink)
mecampo's Avatar
thanks dude
i just replaced the plugs to NGK iridiums and air filter to KNN
do you have instructions on how to clean the throttle body throat?
i'm planning to have the breaks check, still thinking though whether in Just Brakes or NTB.
Please advise.
Old 05-12-2008, 08:37 PM   #4 (permalink)
Gadgetjq's Avatar
To clean the throttle body throat, disconnect the battery negative terminal. (remember to write down your radio station settings first).
1. Pull the intake air 'tunnel' (for lack of a better word) away so you can actually look into the throttle body with a flashlight.
2. Spray some Deep Creep (or just throttle body cleaner if you can't find it) into the throat and let it soak a minute.
3. Have a helper floor the throttle so the butterfly opens all the way.
4. Using an old toothbrush or rag soaked with throttle body cleaner and being VERY careful not to damage the butterfly scrub the area where the butterfly contacts the throat. You'll be able to see a thin carbon ring.
When the carbon is gone close the throttle, button things up. If the above has taken you less than 15 minutes (which is likely) leave the battery disconnected awhile longer. After 15 minutes or so you can re-connect the battery. That allows the ECU to forget all its previous habits which would have included adjusting for air blocked by the carbon (mostly at idle).
When you restart the car don't be too surprised if there's a large cloud of smoke from the exhaust. That'll be the Deep Creep or throttle body cleaner and any carbon it's managed to knock loose inside the combustion chamber.
Now drive the way you normally drive, the car's computer will be re-learning your habits and how to find the proper idle speed for the first few miles.
BTW those with Gen II Solara's have to hold the butterfly open manually inside the throttle body throat. Since there's no more throttle cable a helper can sit in the car all day with the pedal floored and nothing will happen under the hood.
Cheers
Old 05-12-2008, 11:34 PM   #5 (permalink)
mecampo's Avatar
maaaaan, thank god for you and TN
i'll try this next weekend
Oh by the way i just found out that one of my engine mount in the passenger side is ripped does anyone know where i can get an oem or replacement.
thanks
Old 05-12-2008, 11:59 PM   #6 (permalink)
mecampo's Avatar
i'm not sure if its th engine mount or maybe the torque rod
Old 05-13-2008, 08:47 AM   #7 (permalink)
Gadgetjq's Avatar
Google "2002 solara engine mount" and you'll get a list of suppliers. It seems the motor mount 'puck' is around $40 for manual transmission, $30 for automatic from most including this one (hope the link works): http://www2.partstrain.com/store/?N=...263+11921+9199
As always, check with your Toyota dealer to see if they'll match whatever price you find online.
Cheers
Old 05-14-2008, 11:20 AM   #8 (permalink)
mecampo's Avatar
is the torque strut rod the same with torque strut mount or center mount?
