Ken,
Toyota Racing Development sells springs and a heavy duty rear sway bar for your daughters car. There are other aftermarket spring/shock kits available.
It's my understanding each of those items makes some improvement in the way the rear of the Solara handles. The most popular mod (and easiest to install) is the sway bar part #PTR02-06041-01.
Keep in mind each improvement in handling comes at the expense of a slightly harder ride that your daughter might not need or appreciate the same way you would (been there done that with the wife's car).
BTW, TRD also offers a heavy duty shock tower brace for the front of the Solara. It's a lot stouter than the OEM brace installed on the convertible (I don't know if it's stock on the coupe).
Cheers
