Originally Posted by tereza
Hi all,
I have a 2003 Solara (V6) and I was wondering if you are supposed to replace the thermostat at the same time you get your water pump replaced.
Tereza,
Those who are telling you not to replace the thermostat are from the 'if it ain't broke don't fix it' school. On the other side is the proactive fix brigade.
The thermostat which opens and closes fully each time the engine warms up and cools off with constant adjustments while you're driving to keep coolant within a certain temperature range is installed on the engine side of the inlet water hose from the radiator. If it goes bad (which usually means an overheated engine) all the coolant has to be drained, the serpentine drive belt for alternator, power steering etc has to be removed, and the alternator has to come off. THEN you can reach the two bolts holding the thermostate housing to the engine block and finally reach the thermostat itself.
When the water pump and timing belt are being replaced, everything has been removed anyway so why not replace that very important five dollar part?
In the end it's up to you but with (presumably) 90,000 miles or more on your car I'd be replacing not only the thermostat but all radiator and heater hoses too.
Cheers
