02 se rear seat removal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 07-24-2008, 01:14 AM   #1 (permalink)
View bseracka's Photo Gallery
Sorry for asking but can't find an active link to the shop manual. I'm trying to remove the lower part of the rear seats and can't find a release tab or anything. Any clue as to what the trick is?
bseracka is offline   Reply With Quote
Old 07-24-2008, 09:18 AM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
You should be able to pull straight up on the front of the seat (at the base where it meets the floor). That will release spring clips and you can then pull the seat forward and lift out.
If the seat is really stubborn (mine was) use something thin wide and flat like the end of a pry bar (padded so you don't damage the upholstery) to lift the seat about a quarter of the distance from the side of the seat to the center. Once that clip is loose do the same on the other side.
Cheers
Cheers
Gadgetjq is offline   Reply With Quote
