Volume Problems with JVC am/fm/cd
Hello Solara Nation,
I have a 2005 Solara convertible. For the last few weeks I have been experiencing an annoying problem with the JVC am/fm/cd unit.
At first I thought it was with the JVC unit itself. The volume blanks out for about a second then comes back. It does it on am/fm/cd.
Over the weekend I traveled most of the day with the top down and noticed the problem vanished. Later that day sitting in the hot sun I put the top up and immediately the problem returned. Then put the top down again as a test and it vanished again. I did it 2 days straight with the same results.
When the top is retracted there is a circuit that adjusts the volume up to compensate for outside noise. It is now obvious that there is a problem with the adjustment circuit that keeps trying to adjust the volume.
Does anyone know if there is a contact/sensor in the top mechanism and where is it located. I have no problem changing it myself or even bypassing it to eliminate this annoying problem.
Your comments are most welcome!
Thanks,
Randy
