2006 Solara SLE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-08-2008, 08:16 AM   #1 (permalink)
View ckracing's Photo Gallery
2006 Solara SLE V6
I have an '06 Camry Solara SLE V6 that's not a daily driver. Recently surpassed 10K miles - had service performed at local shop (not Toyota dealer). How do you get the maintenance light turned off?
Thanks - Chris
ckracing is offline   Reply With Quote
Old 08-08-2008, 08:55 AM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Thanks - Chris
Hey Chris,
I'll need to charge an hourly rate for this one..... Ready?
Turn on your ignition and push your odometer reset button until the display shows 'total' miles.
Turn off ignition and push the same button but hold it in. Turn on the ignition. Wait and watch the display while you hold the button. The numbers will, one by one, turn to dashes - - - - - - . When all you have are dashes you can let the button go. The maintenance light should be out and should stay out until 5000 miles go by then it'll come on again (solid) to tell you an oil change is due. Notice that light will blink when you start the engine between 4500 and 4999 miles trying to get your attention so you'll do the change 'before' you reach 5000.
You can pay me Tuesday.
Cheers
Gadgetjq is offline   Reply With Quote
Old 08-08-2008, 12:15 PM   #3 (permalink)
hourly rate
Thanks for your help - check's in the mail...
