squeeling ac belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 09-16-2008, 03:35 PM   #1 (permalink)
View jmix's Photo Gallery
squeeling ac belt
I have a 2000 sle v6. The ac belt squeels at low speeds when the ac is pumping. is it tough to change this belt out and if it is not, what is the procedure.
thanks.
jmix is offline   Reply With Quote
Old 09-19-2008, 08:02 PM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Hey JM,
It doesn't appear any GenI Solara owners are jumping in to help you so, for whatever it's worth I'll give it a try. Just keep in mind I have a Gen II so there may be some differences.
Take a look under the hood and you should find a V belt driving your air conditioning compressor (and possibly the power steering pump though that may be on the other belt). There are three ways to fix the squealing.
1. Make sure the belt is tightened properly. General rule of thumb is about 1/2" of slack along the longest section of belt. You should find an adjuster bolt at the bottom of the alternator. Loosen two bolts holding the alternator, adjust the tightening bolt then retighten the two mounting bolts.
2. If the belt is properly adjusted try some belt dressing. You'll find it at any auto supply store. Follow directions on the container. Belt dressing usually ends up being a temporary fix and the squeel will return.
3. Check your owners manual and vehicle mileage. You don't say what your mileage is but maybe it's time for a belt replacement. To replace just get the appropriate size belt from an auto supply or Toyota dealer. Loosen the generator mounting bolts, dial in a bunch of slack with the adjusting bolt then slip off the old belt, slip on the new. The other belt might be in front of the one you're replacing but it'd be a good idea to change both at the same time.
As always I'd recommend you purchase a Chilton or Haynes maintenance manual for your car. They're available at Amazon.com if you can't find one at a local auto supply. The manual is very inexpensive (probably $30 or so) and pictures along with text will help a bunch with any maintenance.
Cheers
Gadgetjq is offline   Reply With Quote
Old 09-22-2008, 07:22 PM   #3 (permalink)
Gadgetjq,
Thanks for the advice. Its sounds simple enough. I am going to get the Haynes or Chilton guide too. The car has 188,000 mile and I don't think this belt has been changed. It's been a great car and will soon be my daughters.
thanks again.
Old 09-22-2008, 07:31 PM   #4 (permalink)
just a nobody
188,000 miles, have you had your timing belt done recently? If you haven't maybe consider having that done, and you can have the belts replaced for no labor, since the belts have to be removed to replace the timing belt anyway.
N.E.O.
Old 09-23-2008, 12:13 AM   #5 (permalink)
Too late, already changed the squeeler. The timing belt has been done although i can recall when.
