It's easy!
I just installed a custom trailer hitch that is hidden behind my license plate, and had to remove/install the rear bumper cover a dozen times, and the tab you talk about is easy to get wrong.
You should(SHOULD!) be able to fix it without removing the bumper, but removing the bumper is an easy 20 minute job.
At the leading edge of the rear bumper cover, at the rear wheel opening, there is a bolt that secures the bumper cover. It's hard to see unless you remove the rear wheel, so I left the wheel on and used a handheld mirror to get my socket on the bolt.
Once that bolt is out, start peeling the top of the bumper cover off, from front to rear. The tabs will pop out and undo without pulling too hard. These will undo all the way to the tab that is misaligned. Make sure you lift the bumper cover up high enough to engage the problem tab, and assemble the cover in the reverse order you took it off. Use the mirror to get the bolt back in.
If you need to remove the whole cover, start with the panel inside the trunk (at the car's rear end, the end closest to the rear bumper). There are three tabs that secure it, pull it off toward the front of the car. That exposes 4 nuts that hold the top of the bumper cover on the car. Don't drop them as you take them off or you'll lose them forever!
Then there are 4 plastic fasteners, one at each bottom, leading edge of the bumper cover, and two under the bottom center of the bumper cover. These fasteners come out if you pull the center out (like the center of a plastic turkey timer pops out). Be careful when the bumper cover comes off, the license plate lights are still connected to the car. Assembly is in the reverse order.
Hope this helps,
Sherm
