P0446: Evaporation Emission Control System Vent Control Malfunction.
The computer is detecting one of the below:
When the VSV for the vapor pressure sensor is off there is no continuity between the vapor pressure sensor and charcoal canister.
When the VSV for vapor pressure sensor is on there is no continuity between the vapor pressure sensor and gas tank.
Once the EVAP system has been purged the pressure in the canister is equal to the atmospheric pressure (the system has a leak).
Items to check are a malfunctioning VSV valve for either the vapor pressure sensor or EVAP valve and their wiring, bad vapor pressure sensor, damaged or disconnected hoses, cracked canister, fuel tank overflow valve damaged.
Toyota has a TSB out on some models to inspect the hoses between and pipes between the EVAP VSV and charcoal canister for leaks and replace the vapor pressure VSV and canister.
Suggest starting out by checking the vapor pressure VSV, this is the vacuum valve on the canister and the canister itself.
Overfilling the tank may lead to issues with the canister failing due to fuel.
