Brake Question/Problem
Hi
I have a 99 Solara SLE.
I just replaced my rear struts and strut mounts, plus sway bar links and bushings because I had the loud banging at right rear that seems somewhat common. While doing this job I noticed the rotors didn't look good at all, though there was lots of meat left on the pads, so I figured I might as well get some new rotors and pads while I was at it.
Anyway, I installed the new rear rotors and ceramic pads. I've done this a few dozen times in the last twenty years, for myself and others, and have never had a problem. This time, however, the pedal is very low & feels somewhat spongy, as if there is air in the line. The thing is, I never opened the bleeder screws. I simply gently squeezed the caliper piston back into it's bore using an old pad and a "C" clamp like I've always done. They went back in very easy.
Why would the pedal be so low and spongy? They won't even pump up to nice, high, and firm. With the crappy messed up rotors there was maybe 1 inch between no brake and total brake.The pedal WAS nice, high, & firm. I could've put an unbuckled passenger through the windshield if I slammed on the brakes. I haven't driven the car yet except for maybe 100' back and forth in front of my house 2-3 times very slowly to see if pedal would stiffen up. They work, the pedal just doesn't feel right at all.
In the past, on all other cars I've owned, I would pump up the brakes in the driveway after 7-8 pedal depressions and then they'd be solid. Good to go.
I could bleed them just to see if it helps, but when replacing the sway bar bushings, both bolts on both sides twisted the heads off and I had to drill out the bolt and re-tap the hole, even though I used PB Buster, waited overnight, then heated them up with a small torch before attmepting to remove them. SO, I really don't want to mess with 9+ year old bleeder screws if I don't have to.
Thanks,
Ron
Raybestos ceramic, what I used, claim to need NO bed in procedure
