timing Belt replacement for V-6 SE - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-28-2008, 01:10 PM   #1 (permalink)
View DCA/PHX's Photo Gallery
I have a '99 Solara SE (V-6) with 61,000 miles. I called up a Toyota dealership and they recommend a timing belt replacement at 90,000 miles or 6 years. Can I gamble a bit and hold off?
DCA/PHX is offline   Reply With Quote
Old 10-28-2008, 07:16 PM   #2 (permalink)
View toyomoho's Photo Gallery
Unless the belt has been subjected to excess dirt, water, sand, oil or other debris the issue is normally total miles not years of use.
Old 10-28-2008, 11:06 PM   #3 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
The maintenance schedule for your car calls for the timing belt to be replaced at 90,000 miles or 108 months (9 years). You can find that information at www.toyotaownersonline.com. The same source says your accessory drive belts should have gotten their first serious inspection at 60,000 miles or 72 months with inspections every 15,000 miles or 18 months after that.
Cheers
Gadgetjq is offline   Reply With Quote
Old 11-08-2008, 04:45 AM   #4 (permalink)
View riceqx2's Photo Gallery
I had mine replace at 125K and asked for the old belt so I could inspect it.
At 125K miles, the belt was showing the threads, so I would have this belt replace at 125K miles but not more than that.
riceqx2 is offline   Reply With Quote
Old 11-18-2008, 10:40 PM   #5 (permalink)
Jakecallun20
Jakecallun20's Avatar
View Jakecallun20's Photo Gallery
I wouldn't recommends this, but I ran my timing belt to 145k. I asked for the old belt as well, and it looked new actually. Lol. My mechanic friend said it would have only lasted for about another year at the most. (Give or take) Its a pricey repair but an important one. Were lucky with 1MZ engines though, they are non-interference engines. I also had my water pump, and crank and cam seals replaced. Car is at 149k now and running strong.
99 Solara SLE V6- Black on Tan: Blackout headlights, FSTB, oil catch can, IK20's, NGK blues, Alpine HU, 12" JL woofer, debadged, custom grill....oh yeah...and fresh paint! I'm an active member of www.solaraguy.com
Jakecallun20 is offline   Reply With Quote
Old 12-31-2008, 04:28 AM   #6 (permalink)
View mh808's Photo Gallery
When to replace a timing belt varies depending on each car's use and environment. I have a 2000 V6 SLE which I hardly use except on weekends. I had less than 24,000 miles in December 2006 and had to replace my timing belt because it became old, dry and hard and started to squeal periodically. If you use the car daily, teh rubber timing belt will stay flexible and lasts a lot longer than the manufacturers recommendation. In my opinion, best to replace the timing belt based on the manufacterer's specs or earlier to prevent getting stalled and risk damaging youe engine's internal components.
mh808 is offline   Reply With Quote
Old 01-07-2009, 01:36 PM   #7 (permalink)
06' tacoma 4x4 LB
View toymkr2's Photo Gallery
drive it for 90,000 . i changed mine at 86,000 still great shape.
toymkr2 is offline   Reply With Quote
Old 01-08-2009, 03:19 PM   #8 (permalink)
Bdub215's Avatar
Gameroom cash: $317765
View Bdub215's Photo Gallery
for a 10 year old car whether the belt looks good or not just replace it. then you wont have to worry about the thought about changing it later. its up to you.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
