Drivers side door and lock cables broke - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-01-2008, 07:27 PM   #1 (permalink)
View jrtredo's Photo Gallery
Hello-
I was getting out of my 99 Solara yesterday and the cable snapped going from the inside door handle to the latch, when I took the panel off i realized that the lock cable also needs to be replaced bc the plastic sheathing where it attaches to the door handle snapped as well.
Has anyone replaced these cable before? I just go the cables from toyota but I dont know how to go about replacing as i cant get to the latch end. Do I need to remove the latch?
Any help greatly appreciated
Thanks
Justin
jrtredo is offline   Reply With Quote
Old 11-01-2008, 07:41 PM   #2 (permalink)
just a nobody
Yes, you do need to remove the latch assembly to disconnect and remove the cables if they are available separately.
N.E.O.
Old 11-02-2008, 09:00 AM   #3 (permalink)
ok i will give it a try
Thanks
Old 11-02-2008, 09:47 AM   #4 (permalink)
i cannot remove the door handle rod that goes to the latch for the life of me from with end. any tricks that anyone knows about?
Thanks!
Old 11-02-2008, 11:02 AM   #5 (permalink)
just a nobody
Used a good side flat blade screw driver between the rod and handle after you have un-clipped it from the rod. Give the screw driver a firm twist; don't force it, otherwise you will break the clip.
N.E.O.
