Serpentine Belt Change Assistance - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-03-2008, 09:58 AM   #1 (permalink)
2004 Camry Solara
View zanzabarpudgemuffin's Photo Gallery
USA Serpentine Belt Change Assistance
Hello Everyone,
I have a 2004 Camry Solara 4 cyl/2.4 L, automatic. I've been trying to change the serpentine belt on my car but can't seem to find the bolt that loosens the pulley tensioner to do it. Can anyone drop me a line and inform and/or direct me to the correct bolt I should be loosening to do the job correctly? Any pics would be helpfull as well. Thanks in advance for any assistance you can throw my way.
Chris
zanzabarpudgemuffin is offline   Reply With Quote
Old 11-05-2008, 12:34 PM   #2 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
If you plan to do anything more complicated than an oil change I'd strongly suggest you either purchase or download a manual. There's a good Chilton manual for the Solara (Amazon.com if you can't find it locally) or you can just download the Toyota factory service manual.
Here's a cut/paste from the factory manual for removal of your belt...It appears you just lever the idler back and lift the belt off. The special tool referred to (SST something) is nothing more than a fancy hook.
DRIVE BELT
REMOVAL
1. REMOVE FRONT WHEEL RH
2. REMOVE FRONT FENDER APRON SEAL RH
3. REMOVE ENGINE COVER SUB-ASSEMBLY NO.1
4. REMOVE ENGINE MOVING CONTROL ROD W/
BRACKET
(a) Remove the 3 bolts and control rod.
5. REMOVE ENGINE MOUNTING STAY NO.2 RH
6. REMOVE ENGINE MOUNTING BRACKET NO.2 RH
7. REMOVE FAN AND GENERATOR V BELT
(a) Slowly turn the belt tensioner clockwise for more
than 3 seconds, and remove the drive belt by using
SST.
SST 09249-63010
Gadgetjq is offline   Reply With Quote
Old 11-05-2008, 12:54 PM   #3 (permalink)
2004 Camry Solara
Thanks for the info. I really appreciate it. Wish me luck.
