Originally Posted by islandtom
All tire pressures including spare are equal @ 32psi.
IT,
Just a little info on the pressure warning system for the '04 Solara. It doesn't actually read the tire pressures like the system in the Gen 2.5 does. The '04 uses the anti lock brake sensors to determine whether one side of the axle is turning faster than the other (based on rotation speed within a few miles of resetting the system). If it is then the light will come on because the slower turning side is, theoretically running with less air in it.
The '04 system also doesn't care about the pressure in your spare tire so air it up to whatever is recommended in your owners manual.
Cheers
