forget about the gas stations it isn't the problem
you are not the only one i have had the gas fill problem since90,000 miles 1 am up too 112,000 now still very slow fill. dealer mechanics say the change the charcoal canister which is between 200-300 dollars just for the part, you have to lower the rear beam or axle to get the damn thing off, personally i think it is the valve in the top of the gas tank filler neck [ which is the roll over flapper] i think this flapper doesn't open up enough when filling the tank which causes the tank not to be venting well enough for fast fill. i have checked all my vent tubes and they all or open that is why i think it is a problem will the fuel tank roll over flapper problem, not an easy fix nor an easy way to test to see if this is the real problem.
