timing belt change - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-24-2008, 10:06 AM   #1 (permalink)
View oldvermonter's Photo Gallery
timing belt change
was wondering if using aftermarket parts when doing a timing belt service would affect the life of the parts some people i have talked to say they will only use factory parts going to install a new belt ,tensioner, idler bearing and water pump. and have found some complete kits. any thoughs would be of great help thanks
oldvermonter is offline   Reply With Quote
Old 11-24-2008, 11:45 AM   #2 (permalink)
View toyomoho's Photo Gallery
Name brand after market parts are fine.
Might use a Toyota OEM or Bando timing belt. Some belts are more prone to making noise then others.
Old 11-25-2008, 06:39 PM   #3 (permalink)
View littlebookworm's Photo Gallery
I agree. Name brand after-market parts are fine. Just follow the directions as outlined in the repair manual. Remember to change the antifreeze and thermostat at the same time. You may have to bleed the air out of the cooling system. The manual will explain if and how. Hope it's warmer where you are than it's here on Long Island NY. I'm waiting until March or April to change mine. Good luck. Hy
littlebookworm is offline   Reply With Quote
