Originally Posted by wkbrdr991
The battery was unplugged for this, and all the "one touch" window features stopped working.
Check your owners manual. Copy/paste from mine:
To recalibrate window operation after a battery disconnect (page 25 in my manual)
1. With the ignition switch in the "on" position push down the power window switch and lower the window halfway.
2. Pull up on the switch until the window closes and hold the switch at least one second.
For the moonroof page 34:
1. With the ignition switch in the 'on' position push and hold the 'tilt up' switch. the pane will tilt all the way up then will tilt down just a little indicating it's set. Now you should be able to just touch the button for any function and the roof will slide all the way open or closed or tilt all the way up and close.
And the answer was in your glove box the entire time
Cheers
