2000 Solara Question. Did search-no luck, Trans Fluid change? quarts? tools? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 12-16-2008, 11:54 AM   #1 (permalink)
gruvee87vertgt's Avatar
View gruvee87vertgt's Photo Gallery
Post 2000 Solara Question. Did search-no luck, Trans Fluid change? quarts? tools?
Howdy!
do I need any special sockets or anything else to change the fluid on this pos
how many quarts do I need? and is it the standered procedure? drain plug on trans pan? fill on top? thanx
I did search too!! no luck!
2001 Svt L, 2000 Toy Solara, 2000 Toy echo
Wont you be my friend?
http://profile.myspace.com/index.cfm...e-34a8a4b64cdf
gruvee87vertgt is offline   Reply With Quote
Old 12-16-2008, 05:21 PM   #2 (permalink)
View toyomoho's Photo Gallery
If auto trans check the drain plug, typically it is a 10mm hex socket.
If draining and refilling you will only get about 1/3 the total capacity, the remaining is in the torque converter.
The amount draining out is about 2 Qts.
Obtain a long nose funnel whose spout can fit into the top of the dipstick tube to add fluid. Add as much fluid as drains out.
Do 3-4 drain and refills with some driving in between and the majority of the fluid should be changed.
Old 12-16-2008, 06:28 PM   #3 (permalink)
cool. thanx
Old 12-16-2008, 09:40 PM   #4 (permalink)
View littlebookworm's Photo Gallery
Trans fluid change
Check your owners' manual or even the dipstick itself as to which fluid you need. My 05 Solara takes a special Toyota fluid. I don't know for sure if yours is the same, but do check. Putting in the wrong fluid will really screw up the transmission. When I did my 05, I had to pour in 5 quarts of fluid to refill it. Some Toyotas have separate drains and fills for the transmission and the differential, though the use the same fluid. Those with a separate setup for the differential are refilled from a fill plug underneath. No real big deal to do, but you have to know which layout you've got. I'd suggest you pick up a repair manual for your car. Makes life a lot easier. Good luck.
littlebookworm is offline   Reply With Quote
