Dealer flush recommendations - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-08-2009, 09:38 AM   #1 (permalink)
View fblair's Photo Gallery
I went in for an oil change today and the dealer had these recommendations.
2005 Solara, 86,000 miles.
A power A/C Evap flush.
An Induction System cleaning.
An E.F.I. flush cleaning.
Any advice on these items?
Thanks,
Fred
fblair is offline   Reply With Quote
Old 01-08-2009, 01:44 PM   #2 (permalink)
View toyomoho's Photo Gallery
How does the AC perform, does it still get cold like it used to?
How does the engine run, acceleration and power OK, MPG not changed.
If all OK, would decline these services.
The AC system is sealed, unless a problem with the AC there is no reason to service it.
The Air Induction System cleaning is a new one. Check the air filter if OK the induction system should be also. If dirty you can change it yourself.
As to injector cleaning unless the engine has a problem this system should be OK. If worried put a bottle of injector cleaner in the fuel tank when it is below 1/4 tank to concentrate the effects then drive the car.
Often these services are recommended to increase dealer income.
Old 01-08-2009, 04:04 PM   #3 (permalink)
that was my first thought, so I asked the Experts.
The only change I have seen is a drop of 1 mpg in the last year or so; some people say that is probably the effect of the Ethanol.
