Removing rear rotor from 99 Solara - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-11-2009, 09:21 PM   #1 (permalink)
View ebbob's Photo Gallery
USA Removing rear rotor from 99 Solara
I hope someone out there can tell me how to remove the rear rotor from my 99 Solara. I am sure it is simple but I've push and pulled to no avail.
ebbob is offline   Reply With Quote
Old 01-12-2009, 10:24 AM   #2 (permalink)
View toyomoho's Photo Gallery
Does the car have rear disk brakes, if so your issue could be emergency brake. The rotor has a drum housing incorporated into it for the E-brake. The drum pads could be extended too much causing them to provent rotor removal.
Old 01-12-2009, 11:00 AM   #3 (permalink)
Old Solaraguy User
View Akfahad's Photo Gallery
^^^yep, release the e-brake. if that doesn't work and if I'm not mistaken, isn't there a screw that screws into the faceplate? I remember vaguely having to do that with mine, and it just popped off. I also had to use a hammer to get some of them off....u know, rust and everything.
Akfahad is offline   Reply With Quote
