2006 Solara SLE V-6 Convertible Electrical Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-29-2009, 08:40 AM   #1 (permalink)
View masksav's Photo Gallery
OK... This one has me stumped. My rear speakers and rear window defroster have stopped working. The light on the dash for the r.w.d. does come on but nothing. The rear seat base was recently removed to fix a carpet issue and I'm not sure if I had the problem before this was done. Is there a fuse or a pinched wiring harness that may be the root of my problem?
The car is a 2006 Solara SLE V-6 Convertible with factory Nav and XM. Also I have a VAIS SLQ installed. The XM and SLQ have been there since day 1 and I've owned the car since new.
masksav is offline   Reply With Quote
Old 02-03-2009, 08:13 PM   #2 (permalink)
View littlebookworm's Photo Gallery
It sounds to me like a connector under the rear seat or carpeting has been disconnected, or the wiring harness has been cut, when the rear seat/carpeting work was done. I'd suggest you bring the car back to whoever did the job and tell them to find out what they did to disconnect your rear wires! Good luck. Hy
littlebookworm is offline   Reply With Quote
Old 02-04-2009, 07:19 AM   #3 (permalink)
Thanks for your reply I'm actually doing that I'll let you know
