Starter Problems: Running When Engine Off - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-30-2009, 02:08 PM   #1 (permalink)
View helbigtw's Photo Gallery
Started her up from sitting for 4 or 5 days in my garage. Started up and the starter would not disengage, terrible noise. Turned the engine off, engine turned off, but the starter continued turning over and over, turned the engine back on, then off again and the starter finally turned off
any ideas?
99 4cyl solara
helbigtw is offline   Reply With Quote
Old 01-30-2009, 07:04 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the starter solenoid (a large relay) bolted to the starter motor. A large battery cable runs to the solenoid.
Your turning the ign key to Start energizes the solenoid allowing power to run from the battery to the stater to motor.
The electrical contacts in the solenoid could be sticking and not releasing.
See links below:
http://www.autozone.com/addVehicleId...00c1528009245e
http://www.autozone.com/addVehicleId...00c15280092462
If not this then could be the starter relay.
