2000 solara sle v6 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-17-2009, 06:39 AM   #1 (permalink)
View danno5069's Photo Gallery
2000 solara sle v6
My horn stopped working, I have pinpointed the problem to the steering wheel, how can I access the contacts w/o activating the airbag. I did a 4 wheel brake job recently, after driving for 20 minutes my check engine light comes on, after driving for another hour my traction control light comes on. I disconnect the battery to eliminate codes but same secuence occurs after driving, any ideas?
danno5069 is offline   Reply With Quote
Old 02-17-2009, 11:57 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I moved your thread to the Solara section. You are more likely to find a solution here than in the Introduction section.
Welcome to TN.
The Jedi Speeder at CarDomain
Old 02-17-2009, 04:25 PM   #3 (permalink)
Welcome to TN.
Thnx, I didnt know how to post
Old 02-18-2009, 08:50 AM   #4 (permalink)
Old Solaraguy User
View Akfahad's Photo Gallery
not sure about the horn thing, but when you were doing the brake job, did you happen to pinch/slice one of the lines? Are you leaking any brake fluid?
Akfahad is offline   Reply With Quote
Old 02-18-2009, 11:06 AM   #5 (permalink)
lines are fine, no leaks, replaced, calipers, and master cylinder. no air in system, completely bled
Old 02-18-2009, 06:40 PM   #6 (permalink)
View littlebookworm's Photo Gallery
You need to double-check with a service manual (which you can find in a library if you don't want to buy one), but ususally, to diactivate the airback system you need to disconnect the battery. Then turn on the headlamps to drain the back-up capacitor. Then carefully disconnect the airbag module. I strongly urge you to get the exact sequence of disconnect from a manual. As to the electrical problems: You need to scan the codes to find out what's going wrong. Obviously, one or more sensors are picking up a problem. I suspect you crimped a wire while you were doing the brake job, but there's no real way to tell from here. Again, a manual with the code and sersor breakdown would help you. Sorry I can't give more detailed advice , but there's just too much unknown here. Hy
littlebookworm is offline   Reply With Quote
Old 02-18-2009, 07:00 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I didn't know the library carried Repair Manuals. Thats a great piece of info!
Old 02-25-2009, 08:36 PM   #8 (permalink)
View sak_kings's Photo Gallery
I had both of te exact same problems. I have a 04 Solara. the engine and the traction light was te gas cap. lol ... I bought one of those computer diagnostic machines. and a Toyota repair manual. I got a fuel press low from the computer. The gas cap was the first thing I checked. Put the gas cap on. reset the code for te engine light. problem solved. the horn. once again repair manual. schematics in the back. disconnect on the horn was the easiset thing to check. there was the problem. problem #2 solved
sak_kings is offline   Reply With Quote
