Urgent, Need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-18-2009, 07:27 AM   #1 (permalink)
View sepulchral's Photo Gallery
Question Urgent, Need help!
Was borrowing my sister's 2001 solara SE while I was doing a 2JZ swap on my supra... and the solara started acting up... Obviously shes going to suspect I did something to it... Need some help troubleshooting.
Symptoms:
Under light throttle at nearly all speeds (at low rpm) the car has this tiny little jerk/hesitation. It will have a couple of them at a a time... It feels like a misfire but I'm not exactly sure.. The car is not throwing ANY codes and CEL is off. I was also getting a dipping idle a few days ago, but it stopped doing that.
Knowns:
Plugs are clean, TB is clean, car idles smooth but at 600rpm (assume its somewhat normal) sometimes it will get the jerk while its idling but very very rarely. Gas is clean, car has good compression.
Needs:
I need to know every thing that could cause this type of interruption and not yield a CEL. I can't narrow it down to certain cylinders because it only does it while driving.
So what would cause all the said problems and not throw a CEL? And if I am to test the two coils, is there a quick way I can test it? Anyone have an FSM they can send me? Michael.G.McDonough@dom.com
THANK YOU!
sepulchral is offline   Reply With Quote
Old 02-18-2009, 07:31 AM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $465374
View BlackCamSe's Photo Gallery
You posted this in the wrong forum. This belongs in the Solara forum.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 02-18-2009, 07:34 AM   #3 (permalink)
Aren't Drivetrains the same as camry? I did that for a reason... This is a 4-cyl auto by the way.
Old 02-18-2009, 07:39 AM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1082658
iTrader Score: 7 reviews
Was going to say if it was a V6, could have been the EGR Valve.
I'll let it sit here for a bit to see if anyone can give an answer. If not i'll move it.
2002 Camry SE V6 "Snow White"
Old 02-18-2009, 07:45 AM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
The 2001 Has the 5S-FE. The same engine thats in the gen4 camry...Try posting this in the gen4 section. They might have more info then we do.
Old 02-18-2009, 07:59 AM   #6 (permalink)
Don't make a new thread...i'll move it to the Solara section in a bit.
Old 02-18-2009, 08:50 AM   #7 (permalink)
thanks mod.
Old 02-18-2009, 11:39 AM   #8 (permalink)
Nobody?
