2000 Blinkers won't work - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-24-2009, 08:14 AM   #1 (permalink)
View pepper76usa's Photo Gallery
USA 2000 Blinkers won't work
Ok guys and gals, my son recently got a 2000 Solara. I can’t seem to get the blinkers to work. I checked the fuses all were fine, power on each side, the hazards work, so it can’t be a bulb. My question is everything else on the switch works fine like the headlights, high beams but I can’t find the flasher? One book a have said the hazards and the blinkers use the same flasher, but another book said it was separate and showed a picture of it under the dash on the drivers side of the steering column. I looked but I can't find one there? Any help would be great.
Thanks
pepper76usa is offline   Reply With Quote
Old 02-25-2009, 08:25 PM   #2 (permalink)
USA
Nobody has any idea?? I really need the help.
Thanks
Old 02-26-2009, 12:19 AM   #3 (permalink)
just a nobody
It does use the same flasher unit. You might have a problem with the turn signal switch itself. Try this and see if it is of any help to you: http://www.camrystuff.com/manuals/Ge...Electrical.pdf. It is for a Camry but should be similar to the Solara.
N.E.O.
Old 02-26-2009, 07:40 PM   #4 (permalink)
Thank you SOOOOO Much N.E.O. !! My God that has a lot of info!! This fourm is great!!!
N.E.O.
Old 03-08-2009, 11:19 PM   #5 (permalink)
View 91MR2quickNA's Photo Gallery
The hazard light switch completes the circuit for the turn signals. If it somehow became unplugged or has an internal fault, you'd be left with no turn signals. If the hazards work when you push the switch, then it's the turn signal stalk/switch on the steering column.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 03-18-2009, 02:52 PM   #6 (permalink)
That guy.
flip3d's Avatar
View flip3d's Photo Gallery
+1 for the switch.
flip3d is offline   Reply With Quote
Old 08-02-2009, 07:16 PM   #7 (permalink)
View mikej48's Photo Gallery
Is that the hazard switch or relay you are talking about?
mikej48 is offline   Reply With Quote
