Here's what's happening...The car (2003 Solara 4 cyl) has a noticable rattle under the hood. When I first heard the car running, I figured it was the serpentine belt tensioner. I popped the belt off, and the noise goes away. So the noise is definitely in the belt path. All of the pulley run smoothly with no noticable wobble. The power steering pump has some noticable shaft endplay, but doesnt make any noise When I put a stethoscope to it though. I pulled the tensioner off of the car, and the pulley spins perfectly. The little shock on the tensioner has a ton of pressure, so I dont think that is the problem either. The waterpump spins freely with no noticable bearing noise, wobble or signs of leaking. The alternator was replaced about a month ago, so it's not the culprit. It's not the heatshield on the exhaust either. When I listen with a stethoscope, I hear noise on the tensioner, and the alternator, but both of those appear to be fine. Does Anyone have any ideas, Or had a similar experiance?
