help with rim sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 07-06-2010, 10:13 PM   #1 (permalink)
View drek20's Photo Gallery
help with rim sizes
Hi, im new to the site...i have a 2002 Solara SLE V6
Im looking at buying some new 18" rims for her, however im not sure how to find rims that will fit properly... know the bolt numbers are 5X114.3, is that all i need to know???
drek20 is offline   Reply With Quote
Old 07-06-2010, 10:28 PM   #2 (permalink)
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1062wt_901
would those fit??
Old 07-06-2010, 10:55 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $954815
iTrader Score: 16 reviews
Aside from the stud pattern (5x114.3), the offset and width of the rim is also very important to know. I had a look at the auction and it states a +40 offset and 8-inch rim width, which should be fine.
Just so you know, the higher the offset is (+) the closer the wheels will sit to the suspension components, and the lower the offset is (-) the further the wheels will sit away from the suspension components and the closer it will sit to the fenders. If the offset is too high (+40 or more) then the wheels will hit/rub against the struts/springs, but if the offset is too low (-35 or less) then the wheels will scrape on the fenders. Either way, both problems are fixable by either using spacers or rolling the fenders, but a +40 offset should be just what you need.
Changing the size of your wheels/tyres also has an affect on your speedometer. I'd highly suggest using the calculators on this site to work out how much of a difference there will be. Just input the size of your old wheels and tyres as well as the size of your new wheels and tyres and it'll tell you exactly how much your speedometer will be affected by:
http://www.carbibles.com/tyre_bible_pg4.html
Old 07-06-2010, 11:00 PM   #4 (permalink)
thanks for the reply...how do i find out the offset on my stock rims??
these are the current stock ones
http://www.finishlinewheels.com/TOYO...02/A-69379U10/
Old 07-06-2010, 11:03 PM   #5 (permalink)
ok nm, i came up with this
So when your speedo reads 70mph, you're actually travelling at mph 68.89
not bad
Old 07-06-2010, 11:13 PM   #6 (permalink)
Full Throttle
I believe the standard offset for those wheels are +45 (however bear in mind that they're only 6-inch in width).
not bad
Yeah that's not bad at all, barely noticeable. Might save you a couple of speeding tickets too, lol.
