Traction Control - how to indentify - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-28-2010, 06:48 PM   #1 (permalink)
Texastrooper
Guest
Posts: n/a
View Texastrooper's Photo Gallery
Hi all I am new here. I am looking to buy a 2007 or 2008 Solara convertible. I am looking for one which has the traction control option installed. Is there an easy way to identify if the model has it? E.g. where is the switch located to toggle on/off the traction control? Or are there easy to identify options which came with it? Dealers normally don't list it and I try to figure out if there is a way to identify it from pictures. I also have a 2004 Sienna and I really like this feature. Oh yes. I am looking for an SLE only. Mainly because heated seats are a MUST. Thanks a lot guys Stefan
Old 08-28-2010, 09:08 PM   #2 (permalink)
View burned300's Photo Gallery
Toyota used a couple of icons for traction control, one is VSC the other is a picture of a car with squiggly lines behind it. one icon or the other should come on when the key is turned on, then after engine is started the light should go out...unless their is a problem light will stay on. some models are set up for the light to come on when you are using the traction control. Darrin
Silver 05 4.7L V8 Tundra AC 4x4
Blue 06 3.3L V6 Seinna LE
Silver 11 3.5L V6 Camry XLE
burned300 is offline   Reply With Quote
Old 08-28-2010, 09:34 PM   #3 (permalink)
Texastrooper
Guest
Posts: n/a
Thanks. The Sienna has switch to deactivate the function. Mainly for driving with chains in winter. Does the solara also have a switch? I would guess so. I just want to check where it is located. Thanks Stefan
