Check Engine Light and Brake Hissing - 1999 Solara
Hi all, have a 1999 Solara with approx 130K miles. The check engine light came on the other day, (misfire in cylinder 1) and reset. Came back on after approx 60 miles of highway driving. Was told to look for vacuum line leaks (not sure exactly which ones). Also there appears to be a slight hissing from the brake booster area. The hissing seems to subside when the brake pedal is pressed down. Having googled and read a few topics might be the brake booster vacuum line? How do you even check it? Would these 2 things be related? Any ideas?
Thanks very much!!
