I agree that it's probably just a tire balancing problem; but it could also be an incorrect tire rotation. Your tires, I believe, are supposed to be rotated front to rear only, not diagnally across. If the wheels were rotated diagnally, the wear pattern on the tires would be upset, causing a vibration. Check for directional arrows on your tires, They may or may not have them. Then get them balanced. If that doesn't fix the problem, have them rotated back the way they were. The only negative to not rotating tires is that the front tires wear out earlier than the rears, rather than all four wearing out at the same time. Hy
