2000 'Lara Heat Issue with Temp Control
Hello Folks-
I've been a Solara owner since end of March- when I bought a 2000 SLE with 130K on it(now has 149,500). I've also posted over on SG forums- but no answers.
During Spring- I noticed it had a slight heat issue- in that after 20 min warmup- the temp would regress back to cool air.
Well- now that its cold here in Northeast- I am noticing the same issues. I have the Auto temp Control with LCD Panel- and AUTO is not on, and does not seem to matter if Re-Circ or Outside Air.
After initial warm-up I get plenty of heat for 20 minutes(or so)- setting is 78 or 79. After that I get a sharp drop-off in temp, and if from floor vents, it may be cool, but if from the upper dash vent or defrost vent- its cold.
I did notice yesterday- driving that if I turned the temp up one degree at a time- it stayed cold all the way to 85 degrees. Once I turned the final step to where LCD said HOT- I got FULL Heat.
I've tried the internal Diagnostics on the LCD panel by hitting the re-circ and auto button while turning on ignition- and all lights go through their process, and then I get Code 21, which is Solar Sensor. The Solar Sensor is the passenger side on top of dash. I swapped out two of those from recently crashed Solaras, but I get the same code. Do I have the correct sensor?
The issue of no tempering or mixing of air- now that I think about- I had the same issue with the AC during the summer. Regardless of what Temp I had on the readout-if I turned the temp up a bit- I got no mixing in of warm air- only FULL AC. I never did try it all the way to HOT.
Could this be the LCD Module itself with its control? Or am I looking at a Sensor? Is Code 21- the Sensor up on top of right side dash?
I did see an on-line version of service manual somewhere- but had no information on the Auto Temp control version, only the Manual control version.
Any Help would be great-
Thank you
Chris
