My guess also would be the compressor; that's the most likely cause of smoke and failure on an AC system. The problem is that the system has now been contaminated with smoke, etc. from the compressor burn-up. The system needs to be checked out, repaired, flushed, and recharged. The diagnosis should be made by someone who knows and is qualified to diagnose, AC problems. The repair can be made by the owner if he/she has mechanical abilities and tools. Replacing a compressor is not a complicated job in itself. The flush, vacuum, and fill must be made by a qualified AC technician. Hy
