Originally Posted by 1gse
The only difference would be fed spec and cali spec sensors. Manual vs auto doesn't make any difference between o2 sensors
M/Ts all used O2 sensors, CA or not. Makes things difficult.
But, a P0135 code means you have a Federal ECU, which uses O2 sensors. If you had a P1135 code, you'd need a wideband O2 sensor (Air-Fuel Ratio sensor) for a CA spec ECU. The connectors are different between the two, so using the wrong sensor is pretty much impossible.
You're okay, though I wouldn't necessarily recommend using Bosch O2 sensors.
