Engine temperature gauge acting wierd!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-28-2011, 08:36 AM   #1 (permalink)
View Solaraowner's Photo Gallery
Hi all,
99 solara v6 sle owner here. So here's my problem:
My engine temperature gauge works perfectly fine when I'm driving in the city. Stays right in the middle between the Hot and Cold lines. When I get on the highway, however, the needle drops almost instantly. Stays at the bottom line right above the C. When I get off the highway and back into city driving, the needle goes back to normal.
Any ideas?!? appreciate the help.
Solaraowner is offline   Reply With Quote
Old 01-30-2011, 06:19 AM   #2 (permalink)
View mikroehl's Photo Gallery
i would look into replacing the theromostat if it really bothers you other than that. As long as it is dropping to the colder side you really don't have to worry, just as long as you aren't seeing it increase. Thermostat's are pretty easy to change your self. Good luck
mikroehl is offline   Reply With Quote
