03 Solara Shaking & Vibrating
Newbie here!
I have a 2003 Solara SE 2.4 Lt. with 225K Miles. I'm the original owner, I've had lots and lots of highway mileage over the years! My Solara has been a great car that I've loved since I saw it in the showroom!
The problem I’ve been experiencing for the last month is as follows:
When driving at a speed of 60 mph, the front of the vehicle starts a steady low shake and vibrates and gradually shakes uncontrollably. The steering wheel vibrates and shakes.
When I decelerate, the shaking still happens but it gradually lessens and when at a complete stop, the car is fine. When accelerating again, the car is ok, no shaking.
This is an intermittent problem that’s getting worse. I can drive at speeds up to 60 mph for up to 40-60 minutes with no issues at all, then the shaking and vibrating will start.
I forgot to mention that my check engine lamp has been lit for a while. The code the last time I had the car serviced was P00116, Cam/Crank Sensor, Sensor A, Bank 1. The mechanic was not able to clear the error and did not replace the crank or cam.
I went to my mechanic and described the problems and left the car. I told him to test drive the car on the parkway and see if he could duplicate the issue. Here are the repairs from that visit:
Problem code P00116 Cam/Crank sensor, Sensor A Bank 1
Tire rotation & balance
Cut front rotors, cut rear drums to correct shimmy
Cut front rotors & rear drums
Replaced cam & crank sensors
The issue is still happening, check engine lamp lit after a few hours of driving. I brought the car back a couple of days later. I drove with the mechanic and the issue didn’t happen. Left the car, they checked the tire balance again and I picked up the car a few hours later.
I brought the car to the dealership and had them run diagnostics and they found the P0016 code is being caused by the timing chain, the timing is off. In between the oil plate and valve cover, some how the chain received some damage. Since I’ve never replaced the chain, they want to replace the chain and it’ll cost upwards of $2K for the repair. They haven’t looked at the shaking & vibrating issue.
Does anyone have any ideas regarding the shaking & vibrating that I’m experiencing?
Any info is greatly appreciated!
Regards,
Mike
Reason: Error in Title
