What is the torque for front brakes caliper bolts on Solara 2006? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-20-2011, 11:28 AM   #1 (permalink)
View xxgrzesx's Photo Gallery
Do you know the torque for the caliper bolts for front brakes for Solara 2006 SLE 6 cylinder. I went to two local stores and they do not have service manual in stock.
If I put Blue Loctite do I have to add more torque to compensate for Loctite or do I still torque it to the required torque. Should I use Loctite at all?
Thanks for responses
xxgrzesx is offline   Reply With Quote
Old 04-23-2011, 07:43 AM   #2 (permalink)
kevdude's Avatar
View kevdude's Photo Gallery
The manual calls for 25 fl lbs on the caliper bolts, and 79 ft lbs for the caliper torque plate (mounting) bolts. Locktite isn't necessary, and you don't need to add or subtract torque to compensate. The bolts are usually hard enough to remove without any locktite! WD-40 is my best friend...
97 Avalon XL, 198,000 miles and still going!
06 Solara SLE convertible
kevdude is offline   Reply With Quote
The Following User Says Thank You to kevdude For This Useful Post:
xxgrzesx (04-23-2011)
Tags
brakes, caliper, loctite
