CEL came on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-25-2005, 11:08 AM   #1 (permalink)
as clever is
View Clever's Photo Gallery
Angry CEL came on
I'm driving home last night , and was sitting at the lights, it goes green so i start to accelerate, all of a sudden my CEL came on and realized that i wasn't getting as much power when i stepped on the gas, then it smelled like a mixture of oil and rubber burning, then the car started to idle really weird to the point that it seemed like it was going to stall but then it doesn't. i'm thinking it's my timing belt but what do i know, i just got the car 3 months ago.any suggestions? this sucks
Clever is offline   Reply With Quote
Old 01-25-2005, 11:23 AM   #2 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
how many km's on your car? the timing belt should be replaced around 100-120, and if it was then there should be a tag saying when it was replaced, so check for that first
Fresco Bob is offline   Reply With Quote
Old 01-25-2005, 11:24 AM   #3 (permalink)
as clever is
just about 80,000 kms
Old 01-25-2005, 11:52 AM   #4 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
gotta get to a atuo parts store and have the code scanned, if you can get that, i guarantee that we can fix it ASAP. The knowledge of these cars is just vast when it comes to fixing problems
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 01-25-2005, 12:38 PM   #5 (permalink)
as clever is
thanks guys, but i'm currently at work right now, good thing i have a company car, i've cancelled my afternoon appointments to spend some quality time with the Solara, it feels like i shouldn't be driving it though, at around 80kms the car started to vibrate pretty bad, so if it's not the timing belt then, i'm going to get it towed to a friends shop, get the malfunction code and go from there i guess, thanks again.
Old 01-25-2005, 12:53 PM   #6 (permalink)
please keep up posted on the issues
Old 01-25-2005, 05:34 PM   #7 (permalink)
as clever is
got the codes
P0401
P0402
any ideas?
Old 01-25-2005, 05:58 PM   #8 (permalink)
as clever is
update:
so the techie in the shop says that there is a misfire in cylinder 1 causing the lack of power, or loss of power. does that make sense?
P0401 - EGR INSUFICIENT FLOW. does that even have to do with anything?
Old 01-25-2005, 06:17 PM   #9 (permalink)
14.3@96mph
View thakidd's Photo Gallery
mark isn't that the same problem u had.....
p0401=egr insuffcient flow detected
(v6 engine)
1.egr valve stuck open
2.open or short in egr gas temperture sensor circuit
3.egr gas temerature sensor malfunction
4.open in vsv circuit for egr
5.egr vsv malfunction
6.vacum control valve malfuntion
7.vacum hose disconnected or blocked
8.pcm malfuction
p0402=egr excessive flow detected
(v6 engine)
2.egr vsv stuck open
3.short in vsv circuit
4.open or short in egr valve postion sensor malfuction
5egr valve postion sensor malfuction
6.pcm malfuction....
"Happieness Is Being Blown"
thakidd is offline   Reply With Quote
Old 01-27-2005, 09:03 AM   #10 (permalink)
if you do a search with just p0401, you will find that quite a few of us has had that issue, its usually just a sticky valve, i would do some of the tricks that some of us used.
Tha Kidd- Yes i had that code, but im sure its different scenario than him. Remember it was my vacuum hoses that were wrong, so the vsv wasnt even opening, so i had an excess build up, but once you came by so i could compare, all was good. Now i just need to fix this o2 sensor problem and i should be good
Old 01-27-2005, 11:34 AM   #11 (permalink)
as clever is
so i find out my car still has warranty , took it to the dealer and so here's the update so far:
here's what the write up from the dealer said "CHECKED CODES FOUND IGNITION COIL ON NUMBER 1 MISFIRING SWITCHED TO 2 AND 5 PROBLEM CARRIED TO THIS CYLINDERS NEEDS COIL"
after doing a search the other day it seems to me that the P0401 / P0402 codes doesn't really make sense, can someone shed some light into this? i can see how the misfire can cause this but not really understand why.
btw: the Traction Control Indicator came on last night too, just came on when i started the car.
Old 01-31-2005, 11:37 AM   #12 (permalink)
View Pone's Photo Gallery
I got this same problem, and i got a v6 auto.. I was told it could possibly be one of my O2 sensors?? Make any sense?? BTW, first post here,
Pone is offline   Reply With Quote
Old 01-31-2005, 01:19 PM   #13 (permalink)
as clever is
welcome!
it ended up to be caused by the misfire(as to why that code came on, i'm still baffled), the vehicle was still under warranty so i took it in and the dealer fixed it, and the Solara's been driving great since. thanks to everyone that helped out, appreciate it.
in regards to your O2 sensors that makes more sense, there's a pretty informative thread posted, just do a search, enjoy your stay.
Old 01-31-2005, 08:11 PM   #14 (permalink)
14.3@96mph
did u ever get a misfire code...so ur car is fixed now
Old 02-01-2005, 04:35 PM   #15 (permalink)
as clever is
the only codes i got was that p0401/ p0402 i was talking to a friend of mine in regards and he pretty much explained that since there was a misfire in the cylinders it wasn't burning the fuel properly/enough so that set off the O2 sensors giving me those codes. yep the Solara is now up and running again.
