solara stock amp - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 07-12-2002, 02:30 PM   #1 (permalink)
View elee102's Photo Gallery
can anyone please tell me if the stock amp in the solara has a built in crossover?
Thanks in advance
elee102
elee102 is offline   Reply With Quote
Old 07-12-2002, 05:54 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
There are NO adjustable crossover capabilities on the OEM stock amp.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 07-12-2002, 07:06 PM   #3 (permalink)
would it be ok to add some adjustable crossovers to my system using the stock amp?
thanks
Old 07-12-2002, 10:38 PM   #4 (permalink)
Luc
Unless you convert the shielded wire-type preamp level from the headunit to RCA, feed the crossover, then convert RCA back to feed the OEM amp, sure. However, you are altering the signals between the OEM headunit and amp, so you WILL pick up some noise. IMO, I don't think it's worth all that risk. You are better off getting a new headunit and an aftermarket amp.
Luc
