Factory Solara Rims - Will they fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-16-2005, 09:20 AM   #1 (permalink)
View SolaraSE1999's Photo Gallery
Hello Everyone,
I am new to the forum and was hoping that some of you more knowledgeable members could steer me in the right direction.
I own a 1999 Solara SE and have come across an opportunity to purchase a set of Toyota OEM 17" rims off of a 2004 Solara, but here are my questions...
1.) will the 2004 17" rims fit on my 1999 Solara SE?
2.) if they will fit, does anyone know if I will have to purchase new lug nuts?
3.) if they will fit, can anyone recommend a moderate tire size that will not present clearance issues?
Thanks in advance for your help...I am relying on you guys since the dealerships seem to know less than the enthusiasts.
Thanks,
SolaraSE1999
SolaraSE1999 is offline   Reply With Quote
Old 02-16-2005, 01:19 PM   #2 (permalink)
Mr. Toyota
View TadS's Photo Gallery
1. Bolt Pattern is 114x5 like Gen 1. They should if the offset is ok, which I think it is.
2. No, should be the same thread size on the wheel studs.
3. 225/45 or 215/50
(2009 Tacoma, 2000 Corolla, 2000 Camry, 2000 Solara, 1995 Avalon XL, 1994 Celica GT)
TadS is offline   Reply With Quote
Old 02-16-2005, 01:31 PM   #3 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
Gen 5 camry wheels will not fit on gen 4 camrys because of a width issue, so i would assume then gen 2 wheels from a solara wouldn't fit gen 1, but you should double check the offset and tire width to make sure
Fresco Bob is offline   Reply With Quote
Old 02-16-2005, 05:55 PM   #4 (permalink)
X Avalon
View hsakuragi's Photo Gallery
check solaraguy.com
hsakuragi is offline   Reply With Quote
Old 02-16-2005, 06:09 PM   #5 (permalink)
Thanks everyone!
Thanks for the info everyone...this forum is great!!
1999SolaraSE
Old 02-17-2005, 10:18 AM   #6 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
Im almost positive they fit, i remember one of the guys at the meet having them on thier car, ill see if i can double check that.
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 02-17-2005, 04:31 PM   #7 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
bob, i've got gen5 xle 16's rims on my gen 4, fitted perfectly! and look great too!
THere is a member on solaraguy who's got gen 2 solara wheels on his gen1 solara. Ask him if he needed spacers in the rear??
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 02-17-2005, 06:29 PM   #8 (permalink)
Mr. Toyota
I saw that post sounded like he had the O.E. Gen 2 tires on his car. I bet that was part of the problem. They're higher profile than we can properly run on a 17. I want to say they're at least a 55 if not bigger. I checked on Tirerack.com and they said a +42 is right for the Gen 2 Solara, an offset that we can also use. So I am a little lost as to what the problem is.
Old 02-17-2005, 11:12 PM   #9 (permalink)
TADS ROCKS!!!
side note, you coming to niagara?
Old 02-18-2005, 12:34 AM   #10 (permalink)
ahhh, my bad then, cause I just remeber the post on here with the guy with the gen5 se and he sold his se rims to another member who drove to pick them up but they had issues with fitment, so I guess Solaras are different afterall
Old 02-18-2005, 07:44 AM   #11 (permalink)
Mr. Toyota
Originally Posted by WortownSolara
TADS ROCKS!!!
Currently Kim and I plan to be there again. I am going to start working (a real job), soon so that could be a factor.
