Toyota Solara turbo kits? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-19-2005, 09:38 PM   #1 (permalink)
View GotSolara?'s Photo Gallery
Does anyone know of any existing 2000+ Toyota Solara turbo kits?
GotSolara? is offline   Reply With Quote
Old 02-19-2005, 09:42 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Yes... By searching, you will find the answer.
There are no v6 kits.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-19-2005, 09:43 PM   #3 (permalink)
No V6 kits? Why?
Old 02-20-2005, 12:19 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
jeez i dont even want to read that reply
just because theres no kits doesnt mean you cant turbo it
terrastrife is offline   Reply With Quote
Old 02-20-2005, 07:58 AM   #5 (permalink)
RedKnight
View JoeB's Photo Gallery
Originally Posted by GotSolara?
No V6 kits? Why?
Hmmm, I'll take a stab at this and please if anybody thinks I'm off my rocker PLEASE chime in!
There is already a supercharger available from TRD for the V6. The sc is instant full time power and not very expensive (depends on your budget ). With the SC, TRD releases the application with a 4psi pulley. Sound pethetic to you? It does to me... The first reaction is to get a smaller pulley and increase to a respectable amount of boost. The problem is, those that don't monitor and add fuel propperly WILL blow knock sensors to start with $$$$. Secondly, you can only go up to 6psi safely with 93 octane pump gas. Try more and your piston ring lands will get toasted! I know I tried it and know others that have as well. Check the link in my sig for pics of my old pistons. The pistons in the 1MZ-FE are some extremely cheap aluminum alloy CRAP.
So now back to the turbo . Low boost turbos typically have a longer spool-up time so if you're going with a low boost setup, it's better to stick with the sc (my opinion). If you wanted to run more boost, you MUST build the engine to handle it. Now to the controvertial part I might get flamed for (I'm ducking ). How many people really fix up Camrys? The truth is, not many. That is why it is so damn difficult to do it. Nobody makes crap for our car even though it is about the most common car out there. Everything you do is custom and very expensive. My bet is a decent turbo setup for a V6 making good boost will set you back $15,000 at a minimum. When you count in all the parts and work that has to go into the drive train to get it to handle it plus the cost of the turbo itself. With that in mind, how much in sales do you think the turbo manufacturer could count on? That's why I think there is no turbo for the V6. -JoeB
Please stop by and rate my ride:
http://www.cardomain.com/id/jbailer
JoeB is offline   Reply With Quote
Old 02-20-2005, 08:07 AM   #6 (permalink)
Mr. Toyota
View TadS's Photo Gallery
^^ That's a good stab. I agree with JoeB the relative cost of a custom turbo kit vs. the TRD Supercharger is just way to high.
(2009 Tacoma, 2000 Corolla, 2000 Camry, 2000 Solara, 1995 Avalon XL, 1994 Celica GT)
TadS is offline   Reply With Quote
