stereo - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 02-28-2005, 08:01 PM   #1 (permalink)
View xrsjustin's Photo Gallery
stereo
how hard is it to put a whole sound system in a 2000 solara sle v6. including a deck, subs and a amp
xrsjustin is offline   Reply With Quote
Old 02-28-2005, 08:13 PM   #2 (permalink)
Mr. Toyota
View TadS's Photo Gallery
No harder than any other car. You don't need anything custom, everything necessary can be purchased off the shelf.
(2009 Tacoma, 2000 Corolla, 2000 Camry, 2000 Solara, 1995 Avalon XL, 1994 Celica GT)
TadS is offline   Reply With Quote
Old 03-01-2005, 08:55 AM   #3 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
Any Toyota is pretty easy to install a system into. If you have any specific info, or just need some help, let any of us know. I have worked in Car Audio for 7 years now, and as you see in the Audio and Video section, there are a TON of knowledgable People out there.
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 03-01-2005, 09:07 AM   #4 (permalink)
View solaraguy672's Photo Gallery
not hard. i have a headunit, sub, and amp. the JBL system is a lil hard to wire into and ur stereo guys will have to do some different connectors for it. other than tht it should be no problem
2000 Solara SLE V6
Looking into an Acura RSX
www.cardomain.com/id/jdmpwr07
solaraguy672 is offline   Reply With Quote
Old 03-01-2005, 03:24 PM   #5 (permalink)
View MOZfreek's Photo Gallery
hey guys...i wanted to install a sub on my Solie....but I dont want to take the stock stereo out....can i hook up an amp and subwoffer into that stereo...or do i have to buy a whole new one.....
MOZfreek is offline   Reply With Quote
Old 03-01-2005, 05:29 PM   #6 (permalink)
Mr. Toyota
There are ways to do this, but it's not really the best way. It's been a while since I talked with anyone about them, but I think that they're called line-level inputs. They allow you to hook the rear speaker connections into the amplifier. There are also converters that do the same thing (the speaker wire goes in RCAs come out). I think there is some pretty bad signal degradation, but I guess that would be something you have to live with if you want to keep the factory deck.
Old 03-02-2005, 06:16 AM   #7 (permalink)
i heard that the stock jbl speakers and the stock deck are amplified already. is this tru and do u have to cross wire everything?
Old 03-02-2005, 09:52 AM   #8 (permalink)
you can integrate into the JBL system no problem, in fact becauase you will be feeding the JBL amp a cleaner signal, your system should take a hike up in quality
And TADS: ur right bro a line-level converter (or hi-to-lo converter) You will loose say 20% of overall quality, not bad considering that you are leaving the rest of the system stock.
PIECE!
Marc
Old 03-02-2005, 02:17 PM   #9 (permalink)
So I have to part with my stock stereo?....I kinda like it, (that and the fact that stereos are like 2 hundred bucks!)....
Old 03-02-2005, 02:41 PM   #10 (permalink)
you do not have to part with your stereo at all, its just not as good of quality as the after market.
Old 03-02-2005, 03:01 PM   #11 (permalink)
Mr. Toyota
Marc
Cool, haven't lost all my knowledge since I left the car audio world (at least in a professional sense) 7 or 8 years ago .
Old 03-03-2005, 06:23 AM   #12 (permalink)
so how would u go about intergrating the jbl system. Also is is true that if ur changing the stock deck for aftermarket u have to cross wire sum wires to bypass a factor amp?
Old 03-03-2005, 06:43 AM   #13 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ This is the wiring harness you need.
http://www.cardomain.com/item/SCOTA03B
The normal Toyota wiring harness will not work with the premium sound systems (ones with a factory amp).
"Skoolin' the unlearned!"
Old 03-03-2005, 08:55 AM   #14 (permalink)
in the solara you can use a normal toyota wiring harness.
Old 03-03-2005, 09:03 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
Hmm...
I thought that all Toyotas with the factory amp need the special wiring harness.
Is it only certain models that need them?
So it looks like I'm wrong. Oh well I have a 88 Camry anyways, so I don't have no stanking factory amp.
